Zum Hauptinhalt wechseln
Cleaning Samsung DVD-P230 Laser Lens
Was du brauchst
  1. Cleaning Samsung DVD-P230 Laser Lens, Outer Cover & Faceplate: Schritt 1, Bild 1 von 3 Cleaning Samsung DVD-P230 Laser Lens, Outer Cover & Faceplate: Schritt 1, Bild 2 von 3 Cleaning Samsung DVD-P230 Laser Lens, Outer Cover & Faceplate: Schritt 1, Bild 3 von 3
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Cleaning Samsung DVD-P230 Laser Lens: Schritt 2, Bild 1 von 1
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Cleaning Samsung DVD-P230 Laser Lens: Schritt 3, Bild 1 von 1
    • Unscrew the 3 screws in the back.
  4. Cleaning Samsung DVD-P230 Laser Lens: Schritt 4, Bild 1 von 2 Cleaning Samsung DVD-P230 Laser Lens: Schritt 4, Bild 2 von 2
    • Pull the outer case upward and then towards you.
  5. Cleaning Samsung DVD-P230 Laser Lens: Schritt 5, Bild 1 von 3 Cleaning Samsung DVD-P230 Laser Lens: Schritt 5, Bild 2 von 3 Cleaning Samsung DVD-P230 Laser Lens: Schritt 5, Bild 3 von 3
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. Cleaning Samsung DVD-P230 Laser Lens: Schritt 6, Bild 1 von 2 Cleaning Samsung DVD-P230 Laser Lens: Schritt 6, Bild 2 von 2
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. Cleaning Samsung DVD-P230 Laser Lens, Power Cord: Schritt 7, Bild 1 von 3 Cleaning Samsung DVD-P230 Laser Lens, Power Cord: Schritt 7, Bild 2 von 3 Cleaning Samsung DVD-P230 Laser Lens, Power Cord: Schritt 7, Bild 3 von 3
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. Cleaning Samsung DVD-P230 Laser Lens, Tray: Schritt 8, Bild 1 von 3 Cleaning Samsung DVD-P230 Laser Lens, Tray: Schritt 8, Bild 2 von 3 Cleaning Samsung DVD-P230 Laser Lens, Tray: Schritt 8, Bild 3 von 3
    • Remove the three screws holding in the DVD tray
  9. Cleaning Samsung DVD-P230 Laser Lens: Schritt 9, Bild 1 von 2 Cleaning Samsung DVD-P230 Laser Lens: Schritt 9, Bild 2 von 2
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. Cleaning Samsung DVD-P230 Laser Lens: Schritt 10, Bild 1 von 2 Cleaning Samsung DVD-P230 Laser Lens: Schritt 10, Bild 2 von 2
    • Gently lift the DVD tray off of the motherboard.
  11. Cleaning Samsung DVD-P230 Laser Lens, Cleaning Samsung DVD-P230 Laser Lens: Schritt 11, Bild 1 von 2 Cleaning Samsung DVD-P230 Laser Lens, Cleaning Samsung DVD-P230 Laser Lens: Schritt 11, Bild 2 von 2
    • Spin small gear shown right to begin opening the tray. There should be relatively little resistance in the gear.
  12. Cleaning Samsung DVD-P230 Laser Lens: Schritt 12, Bild 1 von 3 Cleaning Samsung DVD-P230 Laser Lens: Schritt 12, Bild 2 von 3 Cleaning Samsung DVD-P230 Laser Lens: Schritt 12, Bild 3 von 3
    • Use your fingers to pull the shown tabs towards the sides of the tray, releasing the internal tray that contains the laser.
  13. Cleaning Samsung DVD-P230 Laser Lens: Schritt 13, Bild 1 von 2 Cleaning Samsung DVD-P230 Laser Lens: Schritt 13, Bild 2 von 2
    • Use the cotton swab to wipe off lens
Abschluss
14 weitere Nutzer:innen haben diese Anleitung absolviert.
Mitchell Hart
903 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-30, Regan Winter 2011 Mitglied von Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Mitglieder
8 Anleitungen geschrieben
4 Kommentare
Thank you Mitchell for your clear, concise directions and photos. I was able to dismantle my Samsung DVD-VCR player Model DVD-V2000. It recently quit playing DVD’s, showing a “No Disc” message. It will play CD’s just fine. I cleaned the laser and reinstalled but still no DVD, just CD’s will play. I like the machine and may look into a replacement DVD assembly if I can find one for a reasonable price. Otherwise I’ll upgrade to a new combo unit with the latest bells and whistles. Best wishes, Bill
sherlockbill - Antwort
I successfully fixed the "No Disc" issue on a DVD/VCR model DVD-V5000. Your guide helped and it was basically the same process. I used a foam tip (well a makeup applicator to be more precise) instead of a cotton tip, because it is less likely to leave anything behind like cotton strands. All works now, thanks!
bmtankard - Antwort
Hello Mitchell,
Can I use this procedure to clean the laser of a Samsung D530 dvd player?…..mine also does it’s own thing and generally doesn’t respond to command same as the other users .
Thank you
Brian
Brian Hepke - Antwort
Hello Mitchell, i tried this procedure on an LG 8600c DVD player, basically same procedure and managed to get to lens cleaned it and reassembled everything but now DVD tray doesn’t want to come out and obviously I get the NO DISK message as I cannot load and DVDs. Can you help please ?
Jennifer Farrugia - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 38,573
