Einleitung
This guide leads you through the process of opening up the LabelManager and cleaning the cutting blade. Keep in mind that the device has loose parts. Be careful and keep track of all parts.
Open the label cartridge compartment and remove any current label cartridge to reveal your label cutting blade.
Press down on the exterior button to protrude the blade outward. Once the blade is exposed simply use a microfiber cloth or cotton swab to clean off the blade. Be sure to use rubber cleaning gloves for added safety.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Group 9: Looks good. Great use of the hazard marker for the sharp blade.
