Einleitung
Cleaning the heat sink improves thermal efficiency and overall performance of the engine. It makes sure no debris gets trapped in any opening.
Was du brauchst
Using a 5/16" socket or wrench, remove the three bolts holding the plastic cover on to the engine.
Lift away the plastic cover. Note that the starter is attached to the cover and will come off with it.
Using compressed air and a rag, clean the heat sink.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
