Einleitung
Jamming your hot end is no fun. If your filament is coming out curling, bubbling, or is simply stuck and cannot move in or out of the hot end, you should clear the jam. Here's how.
Was du brauchst
Your printer's hot end is comprised of two stages. The beige plastic part is a thermal break between the 200C heater cartridge and the feeding mechanism above.
The job of the beige part is to keep the filament cool before it reaches the heated element.
The part pictured is made with PEEK plastic. http://reprap.org/wiki/PEEK
For more term definitions, see http://reprap.org/wiki/RepRap_Options#Ex...
Anyway, we're here because this thing is jammed. Read on.
The sock may stick to the brass nozzle. If this happens, use a utility knife to separate the nozzle from the sock.
Heat the hot end to 50 degrees Celsius.
Cold plastic fuses the nozzle to the hot end. This is just enough to soften the PLA plastic without being at the full operating temperature.
Heat the hot end to 230 degrees.
Slacken the idler screw.
Manually push filament through the hot end. Keep a firm pressure through any resistance.
Once the filament comes through the hot end, pull it straight out.
Once the hot end is reassembled, heat to normal 200C and attempt to extrude.
2 Kommentare
Looks like some pictures are missing. Any plans to get those updated?
