Zum Hauptinhalt wechseln
ClickN Kids Tablet Camera Replacement
Was du brauchst
  1. ClickN Kids Tablet Camera Replacement, Camera: Schritt 1, Bild 1 von 1
    • Start on the side with the camera
    • Insert a plastic opening tool into the space between the screen and the back side.
    • The screen side is black, the back side is colored
  2. ClickN Kids Tablet Camera Replacement: Schritt 2, Bild 1 von 1
    • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
    • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
    • The corners can be tricky. Make sure to separate the pieces all the way around the tablet before attempting to open it.
  3. ClickN Kids Tablet Camera Replacement: Schritt 3, Bild 1 von 1
    • Lift the detached screen from the camera side until you can see the inside of the tablet.
    • Don't open too fast, or you might damage the ribbons cables.
  4. ClickN Kids Tablet Camera Replacement: Schritt 4, Bild 1 von 2 ClickN Kids Tablet Camera Replacement: Schritt 4, Bild 2 von 2
    • Be careful not to damage any wires or ribbon cables during this step.
    • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
    • There is a black tab behind the long ribbon cable. Lift up the black tab.
    • For the ribbon cable in the back, pull the black tabs on the side out.
    • Detach the ribbon cables connecting the screen to the motherboard.
    • Remove any tape that is holding down the ribbon cables. Set it aside.
  5. ClickN Kids Tablet Camera Replacement: Schritt 5, Bild 1 von 1
    • Pull off the tape that holds the ribbon cable to the battery.
  6. ClickN Kids Tablet Camera Replacement: Schritt 6, Bild 1 von 2 ClickN Kids Tablet Camera Replacement: Schritt 6, Bild 2 von 2
    • Be careful not to damage the wires or ribbon cables.
    • Pull out the two black ends of the base on the motherboard.
    • Slide out the camera’s ribbon cable once the ends are loosened.
  7. ClickN Kids Tablet Camera Replacement: Schritt 7, Bild 1 von 3 ClickN Kids Tablet Camera Replacement: Schritt 7, Bild 2 von 3 ClickN Kids Tablet Camera Replacement: Schritt 7, Bild 3 von 3
    • Use a plastic opening tool to pry the camera out of its place.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Kevin Finney
562 Reputation
4 Anleitungen geschrieben
Baylor, Team 4-4, Williams Spring 2015 Mitglied von Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 818
