Einleitung
Today a lighter is used more than ever and having the means to replace a part on it can go a long way, especially for your pockets. Clipper lighters have the ability to replace the flint so why not take advantage of this and replace the flint instead of buying a new one each time. Plus it's way more eco-friendly!
This replacement should take no time at all and is something absolutely anyone can do; just be sure to have bought your replacement flint.
Was du brauchst
Purchase flint for lighters - should look cylindrical in nature and small.
Use the top of the lighter housing to twist the cap loose.
Set aside the lighter once it becomes loose enough to do it by hand.
Flip the mechanism and tap on the bottom so that the old flint falls out if there is any left.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
thank you very much for the clear instruction, it was very helpful.
SO Thankful 4this! Wish much more could stay out of landfills!! We're such a wasteful country!!
Easier than I thought...cool dude
Thanks working again
I've got the metal Clipper with a cap over the wheel (EU version). Instead of flicking the wheel with your thumb, you press down on the cap/switch. Now my flint's exhausted and I can't figure out how to remove the cap to change it! Does anyone know?
