Einleitung
This guide will go through the process of cloning your existing software, OS, and data to a new hard drive.
(SuperDuper is now compatible with Big Sur & Monterey.)
NOTE: With the introduction of macOS Catalina, certain steps in this guide are out of date.
IMPORTANT: Cloning the hard drive is not recommended if you have a Mac that uses a recovery partition (MacOS 10.7 - present) or internet recovery (2011 - present). Instead, to move your data to a new drive, first create a backup of your existing drive. Then, either use internet recovery or create a bootable external drive so you’ll be ready to install macOS onto your new drive and migrate your data afterward.
If you are happy with your existing operating system installation and would simply like to upgrade your hard drive capacity, you can clone your existing hard drive to your new drive.
To clone a hard drive, you will need a way to connect the second hard drive to your Mac. Our 2.5" Hard Drive Enclosure or one of our Hard Drive Upgrade Kits works great for cloning your drive over.
To clone your hard drive, we recommend a program called SuperDuper!, by Shirt Pocket Software.
The following instructions assume that you’ll be using SuperDuper! and the 2.5" hard drive enclosure to clone onto a new 2.5" drive. If you are using a different setup, your installation process may be somewhat different.
Was du brauchst
Use the included screwdriver to remove the two Phillips screws.
Set the drive in the plastic tray and align the drive ports with the tray socket.
Carefully push the drive into the tray socket to seat the ports.
Press the drive's raised edge down into the plastic tray.
Flip the drive tray over.
Use the a Phillips screwdriver to install the four mounting screws (included in the kit) to secure the drive to the tray.
Slide the tray back into the aluminum housing.
Reinstall the two Phillips screws to secure the tray.
Power on your Mac and wait for it to fully load.
Plug the enclosure into your Mac's USB port.
Under the Go pulldown menu, select Utilities.
Open Disk Utility from the Utilities window.
Select your new hard drive from the left column in Disk Utility.
Select the Erase option near the top row of buttons.
Select a name for your new drive, and select "APFS" for the format.
Press the erase button.
Quit Disk Utility once the erase is complete.
Download and install SuperDuper!
Under the Go pulldown menu, select Applications.
Open SuperDuper!
In the copy pulldown menu, select your current drive.
In the destination pulldown menu, select the new drive.
In the method pulldown menu, select "Backup—all files".
Press the "Copy Now" button.
If prompted, provide your password.
Click "Copy" when warned about erasing the drive.
Wait for the drive to copy (this could take several hours if you have a lot on your hard drive).
When prompted for registration by SuperDuper!, either choose "Register" to purchase the software or "Later" to register later.
After the copy is complete, click "Ok" and quit SuperDuper!
At this point, your new hard drive should be a clone of your existing drive and ready to install.
Keep the enclosure connected to the computer and restart the computer. Hold down the "option" key as it reboots until a boot option menu shows up.
Select your new hard drive from the boot option menu.
Wait for the computer to boot up to verify if it works properly.
Your new hard drive is now ready to be installed in your computer.
Remove your new hard drive from the external enclosure and install it in your computer. Installation instructions are available for a variety of Macs.
110 weitere Nutzer:innen haben diese Anleitung absolviert.
24 Kommentare
This guide was straightforward and helpful along the way when I replaced my hard drive! My only comment is that this should be a link in the "MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement" article, since the Youtube videos link to each other, but the articles do not. Thanks for all your help with these fantastic guides!
Wow! Thank you Mike.
Everything went very well with a big bonus. My older version of Photoshop does not work with the newer Mac operating systems. Now that I installed a new 1TB hard drive, I can upgrade OS if I want. Then I can use the old drive in an internal enclosure replacing the DVD running the old OS X keeping all of my older Adobe apps!
Ifixit rocks!
Hi BuckNYC,
As far as I know, SuperDuper will not clone the BootCamp partition. You will have to use something like Winclone to do that.
