Zum Hauptinhalt wechseln
Cloth Face Mask Nose Bridge Replacement
Was du brauchst
  1. Cloth Face Mask Nose Bridge Replacement, Nose Bridge: Schritt 1, Bild 1 von 2 Cloth Face Mask Nose Bridge Replacement, Nose Bridge: Schritt 1, Bild 2 von 2
    • It's best to wash your mask before and after handling to ensure cleanliness.
    • Lay the mask flat on desired surface.
    • Optional: Steam mask with a clothing iron to completely flatten and remove wrinkles.
    • Caution: Never leave the clothing iron unattended. Use caution when ironing as the machine will be hot to the touch.
    • Measure out the width of your face mask.
  2. Cloth Face Mask Nose Bridge Replacement: Schritt 2, Bild 1 von 2 Cloth Face Mask Nose Bridge Replacement: Schritt 2, Bild 2 von 2
    • Using a pen or pencil, mark the insertion point for the pipe cleaners.
    • A fabric pencil would be better suited for markings as it can be easily washed off.
  3. Cloth Face Mask Nose Bridge Replacement: Schritt 3, Bild 1 von 1
    • Seam rip where the elastic portion is. If there is no elastic present, then seam rip along the top portion of the mask.
    • Caution: Be mindful of where you place your fingers as it is possible to accidentally jab yourself with the seam ripper.
    • Consider using a thimble for protection.
  4. Cloth Face Mask Nose Bridge Replacement: Schritt 4, Bild 1 von 2 Cloth Face Mask Nose Bridge Replacement: Schritt 4, Bild 2 von 2
    • Cut a 4” strip of pipe cleaner.
    • Use caution when cutting pipe cleaners with scissors.
  5. Cloth Face Mask Nose Bridge Replacement: Schritt 5, Bild 1 von 1
    • Position the pipe cleaner where the markings are and fold the fabric over.
    • You may also use this as an opportunity to test out the positioning of the pipe cleaners before sewing the hem.
  6. Cloth Face Mask Nose Bridge Replacement: Schritt 6, Bild 1 von 1
    • Sew around the pipe cleaner using desired stitch.
    • A basic running stitch is recommended for ease.
    • Try on the mask to ensure the fit is right. Bend the pipe cleaners to best suit your facial frame.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kayla Vargas
157 Reputation
1 Anleitung geschrieben
Texas Tech, Team S3-G15, Cowan Spring 2021 Mitglied von Texas Tech, Team S3-G15, Cowan Spring 2021
TTU-COWAN-S21S3G15
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 595
