Einleitung
The fuse is part of the power cable. It burns out under high electrical current to prevent damage to the radio. The power cable should be disconnected from the power source before starting this guide.
Werkzeuge
Kein Werkzeug erforderlich.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Turn the power switch, the leftmost knob, counterclockwise to off. Turn the power switch, the leftmost knob, counterclockwise to off.
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Turn the device around and firmly pull the power cable plug to remove it from the radio. Turn the device around and firmly pull the power cable plug to remove it from the radio.
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Simultaneously push the fuse container together and rotate counterclockwise. Simultaneously push the fuse container together and rotate counterclockwise.
    • Simultaneously push the fuse container together and rotate counterclockwise.
  5. Pull the two halves apart.
    • Pull the two halves apart.
  6. Remove the fuse from the case. Remove the fuse from the case.
    • Remove the fuse from the case.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
danperoni
485 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 11-37, Amido Fall 2013 Mitglied von Cal Poly, Team 11-37, Amido Fall 2013
CPSU-AMIDO-F13S11G37
4 Mitglieder
9 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 45
Insgesamt: 3,533
