Einleitung
Whether your knobs are broken or you want to put a decorative sticker on your front panel, sometimes you need to get the knobs off of your radio. This guide will instruct you on how to use plastic opening tools to safely remove the knobs.
Was du brauchst
Turn the device around and firmly pull the power cable plug to remove it from the radio.
Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
Gently turn the middle four knobs counter-clockwise until they no longer move.
Insert two plastic opening tools behind the tuning knob.
With some force, pry the knob off of the radio.
To reassemble your device, align the buttons and push them on.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
