Zum Hauptinhalt wechseln
Cobra 29 LTD Classic Knobs Replacement
Was du brauchst
  1. Cobra 29 LTD Classic Knobs Replacement, Power Cable: Schritt 1, Bild 1 von 2 Cobra 29 LTD Classic Knobs Replacement, Power Cable: Schritt 1, Bild 2 von 2
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Cobra 29 LTD Classic Knobs Replacement: Schritt 2, Bild 1 von 2 Cobra 29 LTD Classic Knobs Replacement: Schritt 2, Bild 2 von 2
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Cobra 29 LTD Classic Knobs Replacement, Microphone: Schritt 3, Bild 1 von 2 Cobra 29 LTD Classic Knobs Replacement, Microphone: Schritt 3, Bild 2 von 2
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
  4. Cobra 29 LTD Classic Knobs Replacement: Schritt 4, Bild 1 von 1
    • Gently unplug the microphone plug.
  5. Cobra 29 LTD Classic Knobs Replacement, Knobs: Schritt 5, Bild 1 von 1
    • Gently turn the middle four knobs counter-clockwise until they no longer move.
    • The middle four knobs are held in place by friction and do not have a way to keep them in the correct position. When reassembling the middle four knobs, make sure to line up the mark on the knob with the left-most mark on the front panel.
  6. Cobra 29 LTD Classic Knobs Replacement: Schritt 6, Bild 1 von 2 Cobra 29 LTD Classic Knobs Replacement: Schritt 6, Bild 2 von 2
    • Insert two plastic opening tools behind the tuning knob.
    • With some force, pry the knob off of the radio.
    • Two opening tools are needed so that you don't break the knob or connector by applying uneven force.
  7. Cobra 29 LTD Classic Knobs Replacement: Schritt 7, Bild 1 von 3 Cobra 29 LTD Classic Knobs Replacement: Schritt 7, Bild 2 von 3 Cobra 29 LTD Classic Knobs Replacement: Schritt 7, Bild 3 von 3
    • Repeat the above procedure with the remaining knobs.
    • The final knob will have a power knob on the end of it. When reassembling, put the power knob on last.
Abschluss
To reassemble your device, align the buttons and push them on.
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 11-37, Amido Fall 2013 Mitglied von Cal Poly, Team 11-37, Amido Fall 2013
CPSU-AMIDO-F13S11G37
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 35
Insgesamt: 5,417
