Einleitung
This outer cover is the main cover that protects the inner electrical components. Perform the guide on a flat non-conductive surface to avoid electrical shock and damage to your device.
Was du brauchst
Turn the device around and firmly pull the power cable plug to remove it from the radio.
Unscrew the securing cap counterclockwise from the antenna connector.
Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
