Zum Hauptinhalt wechseln
Cobra 29 LTD Classic Outer Cover Replacement
Was du brauchst
  1. Cobra 29 LTD Classic Outer Cover Replacement, Power Cable: Schritt 1, Bild 1 von 2 Cobra 29 LTD Classic Outer Cover Replacement, Power Cable: Schritt 1, Bild 2 von 2
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Cobra 29 LTD Classic Outer Cover Replacement: Schritt 2, Bild 1 von 2 Cobra 29 LTD Classic Outer Cover Replacement: Schritt 2, Bild 2 von 2
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Cobra 29 LTD Classic Outer Cover Replacement, Antenna Cable: Schritt 3, Bild 1 von 2 Cobra 29 LTD Classic Outer Cover Replacement, Antenna Cable: Schritt 3, Bild 2 von 2
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Cobra 29 LTD Classic Outer Cover Replacement: Schritt 4, Bild 1 von 2 Cobra 29 LTD Classic Outer Cover Replacement: Schritt 4, Bild 2 von 2
    • Gently pull the antenna cable to remove it from the back of the radio.
  5. Cobra 29 LTD Classic Outer Cover Replacement, Microphone: Schritt 5, Bild 1 von 2 Cobra 29 LTD Classic Outer Cover Replacement, Microphone: Schritt 5, Bild 2 von 2
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
  6. Cobra 29 LTD Classic Outer Cover Replacement: Schritt 6, Bild 1 von 1
    • Gently unplug the microphone plug.
  7. Cobra 29 LTD Classic Outer Cover Replacement, Outer Cover: Schritt 7, Bild 1 von 2 Cobra 29 LTD Classic Outer Cover Replacement, Outer Cover: Schritt 7, Bild 2 von 2
    • Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
  8. Cobra 29 LTD Classic Outer Cover Replacement: Schritt 8, Bild 1 von 3 Cobra 29 LTD Classic Outer Cover Replacement: Schritt 8, Bild 2 von 3 Cobra 29 LTD Classic Outer Cover Replacement: Schritt 8, Bild 3 von 3
    • Gently life and remove the top cover.
  9. Cobra 29 LTD Classic Outer Cover Replacement: Schritt 9, Bild 1 von 3 Cobra 29 LTD Classic Outer Cover Replacement: Schritt 9, Bild 2 von 3 Cobra 29 LTD Classic Outer Cover Replacement: Schritt 9, Bild 3 von 3
    • Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio.
    • Carefully flip the radio over.
  10. Cobra 29 LTD Classic Outer Cover Replacement: Schritt 10, Bild 1 von 2 Cobra 29 LTD Classic Outer Cover Replacement: Schritt 10, Bild 2 von 2
    • Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
  11. Cobra 29 LTD Classic Outer Cover Replacement: Schritt 11, Bild 1 von 3 Cobra 29 LTD Classic Outer Cover Replacement: Schritt 11, Bild 2 von 3 Cobra 29 LTD Classic Outer Cover Replacement: Schritt 11, Bild 3 von 3
    • Watch out for the wires connected to the speaker. These short wires will not allow you to move the cover very far.
    • Gently lift and remove the case cover.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Chase
267 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 11-37, Amido Fall 2013 Mitglied von Cal Poly, Team 11-37, Amido Fall 2013
CPSU-AMIDO-F13S11G37
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 24
Insgesamt: 1,727
