Zum Hauptinhalt wechseln
Coby DVD-R11000 3-Pin Power Cable Replacement
Was du brauchst
  1. Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: Schritt 1, Bild 1 von 3 Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: Schritt 1, Bild 2 von 3 Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: Schritt 1, Bild 3 von 3
    • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
    • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
    • It is not required to remove the other seven screws in the middle between the I/O ports.
  2. Coby DVD-R11000 3-Pin Power Cable Replacement: Schritt 2, Bild 1 von 3 Coby DVD-R11000 3-Pin Power Cable Replacement: Schritt 2, Bild 2 von 3 Coby DVD-R11000 3-Pin Power Cable Replacement: Schritt 2, Bild 3 von 3
    • Position the DVD player so that the back is facing you
    • Grab underneath the sides of the DVD player and lift the front of it upwards.
    • Carefully pull the top of the casing off
  3. Coby DVD-R11000 3-Pin Power Cable Replacement, 3-Pin Power Cable: Schritt 3, Bild 1 von 2 Coby DVD-R11000 3-Pin Power Cable Replacement, 3-Pin Power Cable: Schritt 3, Bild 2 von 2
    • Gently pinch the 3-pin white adapter of the wire connecting the power cord to the circuit board.
    • Remove the wire from the circuit board.
Abschluss
Andrew
501 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 1-6, Shastany Fall 2014 Mitglied von UMass Dartmouth, Team 1-6, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G6
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 477
