Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
  1. Press the eject button to view the laser inside. Using the blue plastic tool and the tweezers, remove the ribbon cable. Using the blue plastic tool and the tweezers, remove the ribbon cable.
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver. Do not lift the top of the DVD player too quickly because there are wires attached on the inside. Pry the top of the device open from the right side where the buttons are located.
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them. Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board. Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Take the top portion of the DVD player and orient the device as shown in the first picture. Remove the four 0.2" screws circled in red.
    • Take the top portion of the DVD player and orient the device as shown in the first picture.
    • Remove the four 0.2" screws circled in red.
  5. Losen the screw circled in red. The screw will not come out of the plastic knob. Turn the plastic knob 90 degrees to the right so that the cable comes out freely.
    • Losen the screw circled in red.
    • The screw will not come out of the plastic knob.
    • Turn the plastic knob 90 degrees to the right so that the cable comes out freely.
Abschluss
Yufay Chow
92 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 10-36, Amido Winter 2012 Mitglied von Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 342
