Was du brauchst
Press the eject button to view the laser inside.
Using the blue plastic tool and the tweezers, remove the ribbon cable.
Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
Pry the top of the device open from the right side where the buttons are located.
Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
Take the top portion of the DVD player and orient the device as shown in the first picture.
Remove the four 0.2" screws circled in red.
Losen the screw circled in red.
Turn the plastic knob 90 degrees to the right so that the cable comes out freely.
