Zum Hauptinhalt wechseln
Coby KYROS MID7125 Side Lock Button Replacement
Was du brauchst
  1. Coby KYROS MID7125 Side Lock Button Replacement, Side Lock Button: Schritt 1, Bild 1 von 1
    • Begin by removing back panel using the large opening tool.
  2. Coby KYROS MID7125 Side Lock Button Replacement: Schritt 2, Bild 1 von 3 Coby KYROS MID7125 Side Lock Button Replacement: Schritt 2, Bild 2 von 3 Coby KYROS MID7125 Side Lock Button Replacement: Schritt 2, Bild 3 von 3
    • Remove the connection of all of the ribbon cables connected to the motherboard of the device using the Plastic Spudger.
  3. Coby KYROS MID7125 Side Lock Button Replacement: Schritt 3, Bild 1 von 1
    • Use plastic Spudger to remove the battery off of the panels and and leave it unconnected until the device is being put back together.
    • Review Battery Replacement for details on how to remove battery.
  4. Coby KYROS MID7125 Side Lock Button Replacement: Schritt 4, Bild 1 von 2 Coby KYROS MID7125 Side Lock Button Replacement: Schritt 4, Bild 2 von 2
    • Using the philips head screw driver size PH0, unscrew the screws holding the mother board to the device.
  5. Coby KYROS MID7125 Side Lock Button Replacement: Schritt 5, Bild 1 von 1
    • Using the plastic Spudger, pop the mother board out of place to expose the broken button piece.
    • Be sure to not pull the mother board out to much, some of the soldered wired connections may break.
  6. Coby KYROS MID7125 Side Lock Button Replacement: Schritt 6, Bild 1 von 1
    • Use the plastic Spudger to remove broken power button, and then pop in new power button after removal.
    • Reverse steps 1-5 to reassemble.
Abschluss
UMass Dartmouth, Team 5-2, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
For people wondering: Yes, this does work on a MID7120, because the MID7120's board is similar to the MID7125's board. Also, where can I get switches similar to these? My MID7120 is missing the switch so I can't turn it on.
KineTheFish - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 189
