Zum Hauptinhalt wechseln
Coby Kyros MID7125 Battery Replacement
Was du brauchst
  1. Coby Kyros MID7125 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
  2. Coby Kyros MID7125 Battery Replacement: Schritt 2, Bild 1 von 1
    • Locate battery. The battery is the silver coated square shaped device on the top of the motherboard.
  3. Coby Kyros MID7125 Battery Replacement: Schritt 3, Bild 1 von 1
    • There is a small ribbon cable located under the battery. running from the volume buttons underneath the batter to main logic board.
  4. Coby Kyros MID7125 Battery Replacement: Schritt 4, Bild 1 von 1
    • Knowing the location the ribbon cable, use plastic spudger to pry off battery.
  5. Coby Kyros MID7125 Battery Replacement: Schritt 5, Bild 1 von 1
    • After the battery is free from the logic board, find the positive and negative wires that connect the battery to the motherboard
  6. Coby Kyros MID7125 Battery Replacement: Schritt 6, Bild 1 von 1
    • Using a soldering gun, heat up both soldering points.
    • Remove wires from logic board
    • Clean up soldering joints with a desoldering sucker
    • Solder the new battery wires to the same soldering points as the old battery
    • Reverse steps 1-5 to put device back together
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan
108 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 5-2, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 354
