Zum Hauptinhalt wechseln
Coby Kyros MID7125 Speaker Replacement
Was du brauchst
  1. Coby Kyros MID7125 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Use opening too to make small opening in the side of the device.
    • Use plastic opening tool to pry the rest of the panel off.
  2. Coby Kyros MID7125 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Once inside the device, locate the speakers on the inside of the back panel.
  3. Coby Kyros MID7125 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Use spudger to pry one speaker up off of the back panel.
  4. Coby Kyros MID7125 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Desolder the soldering points that connect the speaker to the motherboard.
  5. Coby Kyros MID7125 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Use a soldering iron to solder the wires of the new speaker to the motherboard.
    • Make sure, when soldering, to connect the red wire to the red and the black wire to the black.
  6. Coby Kyros MID7125 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Click the new speaker into the spot where you removed the old speaker.
    • Follow steps 2-6 for the other speaker. Snap in back panel to put device back together.
Abschluss
Nicole Connelly
1 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 5-2, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 131
