Einleitung
This guide is provided to those who may need assistance on replacing their camera for a "Coby Kyros MID9042" tablet. Replacing the camera on a Coby Kyros MID9042 can be challenging but before you begin, make sure you have the necessary tools, a replacement camera, and a clean, well-lit workspace. Here's a step-by-step guide to help you through the process. Remember to exercise caution throughout the process, and if you encounter any difficulties, consult the device's user manual or seek assistance.
Was du brauchst
After powering off device, remove the anti-slip pads from all 4 corners on the back of the device.
Once slip pads are removed, proceed to unscrewing the four 3.2 mm Phillips #0 screws from the back cover.
Use the blue plastic opening tool to wedge the back cover apart from the front.
Once the edges are wedged apart, use hands to lift up the back of the tablet.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Locate the gold flap and use tweezers to lift the flap up.
Use a second pair of tweezers to pull the gold tab connected to the camera out of the circuit board.
Once the tab is removed from the circuit board, pull the camera out of the tablet.
