Zum Hauptinhalt wechseln
Coby Kyros MID9742 Camera Module Replacement
Was du brauchst
  1. Coby Kyros MID9742 Camera Module Replacement, Outer Casing: Schritt 1, Bild 1 von 1
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Coby Kyros MID9742 Camera Module Replacement: Schritt 2, Bild 1 von 1
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. Coby Kyros MID9742 Camera Module Replacement: Schritt 3, Bild 1 von 1
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
  4. Coby Kyros MID9742 Camera Module Replacement, Camera Module: Schritt 4, Bild 1 von 1
    • Remove the two ribbon cables attached to the logic board.
  5. Coby Kyros MID9742 Camera Module Replacement: Schritt 5, Bild 1 von 1
    • Remove the tape covering the ribbon cables and remove the camera module.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jake
158 Reputation
1 Anleitung geschrieben
Colorado Springs, Team 5-3, Panko Spring 2015 Mitglied von Colorado Springs, Team 5-3, Panko Spring 2015
UCCS-PANKO-S15S5G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 192
