Zum Hauptinhalt wechseln
Coby Kyros MID9742 Motherboard Replacement
Was du brauchst
  1. Coby Kyros MID9742 Motherboard Replacement, Outer Casing: Schritt 1, Bild 1 von 1
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Coby Kyros MID9742 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. Coby Kyros MID9742 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
  4. Coby Kyros MID9742 Motherboard Replacement, Battery: Schritt 4, Bild 1 von 1
    • Use a soldering iron to remove the connection between the red wire first then proceed to the black wire.
  5. Coby Kyros MID9742 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Use the PH00 screwdriver to remove the six 0.25 cm screws circled in the image.
  6. Coby Kyros MID9742 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the ribbon cables by gently lifting the black tabs and pulling out the cable.
    • This will allow the user to lift and remove the motherboard from the tablet.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ian Swett
597 Reputation
5 Anleitungen geschrieben
Colorado Springs, Team 5-3, Panko Spring 2015 Mitglied von Colorado Springs, Team 5-3, Panko Spring 2015
UCCS-PANKO-S15S5G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 13
Insgesamt: 469
