Einleitung
This process is easy, but will require some soldering.
Ersatzteile
Keine Ersatzteile angegeben.
Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
Use a soldering iron to remove the connection between the red wire first then proceed to the black wire.
Use the PH00 screwdriver to remove the six 0.25 cm screws circled in the image.
Remove the ribbon cables by gently lifting the black tabs and pulling out the cable.
Ein weiterer Nutzer hat diese Anleitung absolviert.
