Einleitung
The purpose of this guide is to give step-by-step instruction on how to replace the motherboard on a ColecoVision.
Was du brauchst
Start by laying the console face down.
Remove the eight 15mm Phillips #1 screws from the bottom of the device.
Flip the console back over.
Lift the front panel off. I would reccomended using a metal spudger along the rim of the top to safely remove it and set it aside.
Remove the two 15mm Phillips #1 screws holding the casing in place.
Carefully lift the casing from the motherboard.
Remove the center Phillips #1 screw near the cartridge slot.
Remove the second Phillips #1 screw near the RAM chips.
Carefully lift and remove the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
