Zum Hauptinhalt wechseln
Coleman Rechargeable Fluorescent Twin Tube Battery Replacement
Was du brauchst
  1. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: Schritt 1, Bild 1 von 2 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: Schritt 1, Bild 2 von 2
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: Schritt 2, Bild 1 von 1
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: Schritt 3, Bild 1 von 2 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: Schritt 3, Bild 2 von 2
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: Schritt 4, Bild 1 von 3 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: Schritt 4, Bild 2 von 3 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: Schritt 4, Bild 3 von 3
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
Abschluss
Sean
265 Reputation
2 Anleitungen geschrieben
Washington State, Team S2-G1, Hope Fall 2018 Mitglied von Washington State, Team S2-G1, Hope Fall 2018
WSU-HOPE-F18S2G1
4 Mitglieder
8 Anleitungen geschrieben
1 Kommentar zur Anleitung
Sean, I’m facing a dead battery in my Coleman twin tube fluorescent lantern also. Your directions are spot on except my battery seems to be glued in with super glue! I’ve tried a heat gun and all my strength but my battery won’t come loose. I find it hard to pry under the battery because of the shape of the plastic partitions around the battery. How did you get the battery unstuck?
BilMcKelvy - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 31
Letzte 30 Tage: 109
Insgesamt: 6,487
