Zum Hauptinhalt wechseln
Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement
Was du brauchst
  1. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: Schritt 1, Bild 1 von 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: Schritt 1, Bild 2 von 2
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: Schritt 2, Bild 1 von 1
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: Schritt 3, Bild 1 von 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: Schritt 3, Bild 2 von 2
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: Schritt 4, Bild 1 von 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: Schritt 4, Bild 2 von 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: Schritt 4, Bild 3 von 3
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
  5. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: Schritt 5, Bild 1 von 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: Schritt 5, Bild 2 von 2
    • Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
    • Remove the plastic barrier.
  6. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: Schritt 6, Bild 1 von 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
  7. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: Schritt 7, Bild 1 von 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: Schritt 7, Bild 2 von 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: Schritt 7, Bild 3 von 3
    • Gently grab the main board by the exposed PCB.
    • Pull the main board straight out of the housing.
Abschluss
Mathew Merrick
169 Reputation
2 Anleitungen geschrieben
Washington State, Team S2-G1, Hope Fall 2018 Mitglied von Washington State, Team S2-G1, Hope Fall 2018
WSU-HOPE-F18S2G1
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 28
Insgesamt: 874
