Zum Hauptinhalt wechseln
Einleitung
If you press a button and the button does not move or if people cannot hear you talking while the talk button is pressed down, the buttons may need to be cleaned or replaced.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Look for the release button on the back of the radio. Press the button and pull down on the battery at the same time. The battery will come free. Press the button and pull down on the battery at the same time. The battery will come free.
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. Twist the antenna counter-clockwise to unscrew it from the antenna jack.
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  4. Pull up on the dials to remove them from the underlying pegs.
    • Pull up on the dials to remove them from the underlying pegs.
  5. Using a T15 Torx screwdriver, unscrew the two screws. Using a plastic opening tool, pry the internal case from the external case. Using a plastic opening tool, pry the internal case from the external case.
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  6. Grip the corner of the button pad and gently peal it away from the faceplate. Clean off any sticky residue and/or replace the buttons.
    • Grip the corner of the button pad and gently peal it away from the faceplate.
    • Clean off any sticky residue and/or replace the buttons.
Abschluss
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 112
