Einleitung
This guide shows how to remove the antenna, volume and channel dials, and the exterior case.
Was du brauchst
Look for the release button on the back of the radio.
Press the button and pull down on the battery at the same time. The battery will come free.
Twist the antenna counter-clockwise to unscrew it from the antenna jack.
Using a T15 Torx screwdriver, unscrew the two screws.
Using a plastic opening tool, pry the internal case from the external case.
