Zum Hauptinhalt wechseln
ComNet Ericsson Panther 600P Motherboard Replacement
Was du brauchst
  1. ComNet Ericsson Panther 600P Motherboard Replacement, Locate the release button.: Schritt 1, Bild 1 von 3 ComNet Ericsson Panther 600P Motherboard Replacement, Locate the release button.: Schritt 1, Bild 2 von 3 ComNet Ericsson Panther 600P Motherboard Replacement, Locate the release button.: Schritt 1, Bild 3 von 3
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Motherboard Replacement, Antenna: Schritt 2, Bild 1 von 1
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Motherboard Replacement, Dials: Schritt 3, Bild 1 von 1
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Motherboard Replacement, Exterior Case: Schritt 4, Bild 1 von 3 ComNet Ericsson Panther 600P Motherboard Replacement, Exterior Case: Schritt 4, Bild 2 von 3 ComNet Ericsson Panther 600P Motherboard Replacement, Exterior Case: Schritt 4, Bild 3 von 3
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Motherboard Replacement, Front Case - Internal: Schritt 5, Bild 1 von 3 ComNet Ericsson Panther 600P Motherboard Replacement, Front Case - Internal: Schritt 5, Bild 2 von 3 ComNet Ericsson Panther 600P Motherboard Replacement, Front Case - Internal: Schritt 5, Bild 3 von 3
    • Using the plastic opening tool, pry the case apart.
  6. ComNet Ericsson Panther 600P Motherboard Replacement, Ribbon: Schritt 6, Bild 1 von 2 ComNet Ericsson Panther 600P Motherboard Replacement, Ribbon: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • The keypad chip is attached to the motherboard by a ribbon.
    • Pull ribbon with tweezers to detach from back panel.
  7. ComNet Ericsson Panther 600P Motherboard Replacement, Screen: Schritt 7, Bild 1 von 3 ComNet Ericsson Panther 600P Motherboard Replacement, Screen: Schritt 7, Bild 2 von 3 ComNet Ericsson Panther 600P Motherboard Replacement, Screen: Schritt 7, Bild 3 von 3
    • Screen will be attached by a ribbon.
    • Pull screen up and away from motherboard to detach.
  8. ComNet Ericsson Panther 600P Motherboard Replacement, Antenna, Volume, Channel Nuts: Schritt 8, Bild 1 von 3 ComNet Ericsson Panther 600P Motherboard Replacement, Antenna, Volume, Channel Nuts: Schritt 8, Bild 2 von 3 ComNet Ericsson Panther 600P Motherboard Replacement, Antenna, Volume, Channel Nuts: Schritt 8, Bild 3 von 3
    • Remove the rubber O-rings from the antenna jack, volume switch, and channel switch.
    • Once the rubber O-rings have been removed, use small needle nose pliers to unscrew the nuts on the antenna jack, volume switch, and channel switch.
    • There are washers underneath the nuts on the antenna jack, volume switch, and channel switch. Set these washers aside.
  9. ComNet Ericsson Panther 600P Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Using a T15 Torx screwdriver, unscrew the 3.8mm screw from the case.
  10. ComNet Ericsson Panther 600P Motherboard Replacement, Internal Case - Back: Schritt 10, Bild 1 von 3 ComNet Ericsson Panther 600P Motherboard Replacement, Internal Case - Back: Schritt 10, Bild 2 von 3 ComNet Ericsson Panther 600P Motherboard Replacement, Internal Case - Back: Schritt 10, Bild 3 von 3
    • Using any convenient hand-placement, pull the motherboard away from the case.
    • The antenna jack, volume dial, and channel dial are attached to the motherboard. Be sure to pull the motherboard downward so they clear their respective slots in the case.
    • Lift the motherboard completely free of the case.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 327
