Einleitung
If your Comfort Zone CZ6C loosely attaches onto surfaces, then this simple, two-step guide will help you replace the clamp.
Was du brauchst
Turn the Comfort Zone CZ6C onto its backside.
Locate the center hinge screw.
With a Philips screwdriver, remove the center hinge screw.
Once the center hinge screw is completely removed from its hole, detach the clamp from the Comfort Zone CZ6C.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
