Zum Hauptinhalt wechseln
Einleitung
Before replacing your fan's motor, use this Comfort Zone CZ6C Fan Blades Replacement Guide.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Make sure to unplug the Comfort Zone CZ6C before replacing the motor. This will prevent the risk of electrocution. Unscrew the main housing screw located right above the main switch using a Phillips screwdriver. Then use gentle force to remove the main housing door.
    • Make sure to unplug the Comfort Zone CZ6C before replacing the motor. This will prevent the risk of electrocution.
    • Unscrew the main housing screw located right above the main switch using a Phillips screwdriver.
    • Then use gentle force to remove the main housing door.
    • Remember to keep track of your screws!
  2. Unscrew the two adjacent housing screws to free the motor cage from the housing. Unscrew the two adjacent housing screws to free the motor cage from the housing. Unscrew the two adjacent housing screws to free the motor cage from the housing.
    • Unscrew the two adjacent housing screws to free the motor cage from the housing.
  3. Remove the motor cage from the fan housing. Remove the motor cage from the fan housing. Remove the motor cage from the fan housing.
    • Remove the motor cage from the fan housing.
  4. Unscrew the two adjacent motor cage screws to free the motor Unscrew the two adjacent motor cage screws to free the motor
    • Unscrew the two adjacent motor cage screws to free the motor
  5. The motor is now free to be replaced. If the motor will not move out of its now freed state you can use WD-40 to loosen it If the motor will not move out of its now freed state you can use WD-40 to loosen it
    • The motor is now free to be replaced.
    • If the motor will not move out of its now freed state you can use WD-40 to loosen it
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Gage Wilson
196 Reputation
1 Anleitung geschrieben
Cal Poly, Team 17-5, Forte Spring 2015 Mitglied von Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 9
Letzten 30 Tage: 38
Insgesamt: 3,477
