Einleitung
Learn how to effectively replace the switch of your Comfort Zone CZ6C
Was du brauchst
Start with the fan on its back. Unscrew the back panel to expose the internal wiring.
Remove the plastic cover on the switch by pulling it apart from the the back panel.
Strip the green and yellow wire about two centimeters from where it was just cut.
After replacing the switch, resolder the gray power cord, the green wire, and the yellow wire.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
I need a replacement switch for a Comfort Zone CZ40 heater. Can you help?
