Zum Hauptinhalt wechseln
Commodore 64 Removing the Shift-Lock Key
Was du brauchst
  1. Commodore 64 Removing the Shift-Lock Key, Removing the screws: Schritt 1, Bild 1 von 3 Commodore 64 Removing the Shift-Lock Key, Removing the screws: Schritt 1, Bild 2 von 3 Commodore 64 Removing the Shift-Lock Key, Removing the screws: Schritt 1, Bild 3 von 3
    • 1. Remove three 6.75mm ph2 screw heads from the casing.
  2. Commodore 64 Removing the Shift-Lock Key, Opening the Case: Schritt 2, Bild 1 von 1
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
  3. Commodore 64 Removing the Shift-Lock Key, Removing screws (continued): Schritt 3, Bild 1 von 1
    • 3. Remove eight 6.75 mm ph2 screw heads to detach the keyboard face from the front casing. (Two remaining screws on the right side.)
  4. Commodore 64 Removing the Shift-Lock Key, Removing Screws (continued): Schritt 4, Bild 1 von 1
    • 4. Remove twenty-three 3.38 mm ph2 screw heads from the back of the keyboard facing
  5. Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: Schritt 5, Bild 1 von 3 Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: Schritt 5, Bild 2 von 3 Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: Schritt 5, Bild 3 von 3
    • 5. Detach the multi-colored wire bundles connected to the motherboard
  6. Commodore 64 Removing the Shift-Lock Key, Cutting the Wires: Schritt 6, Bild 1 von 1
    • 6. Next, carefully cut the two small wires which are connected from the Shift/Lock key to the keyboard.
  7. Commodore 64 Removing the Shift-Lock Key, Removing the Shift-Lock key: Schritt 7, Bild 1 von 2 Commodore 64 Removing the Shift-Lock Key, Removing the Shift-Lock key: Schritt 7, Bild 2 von 2
    • 7. Turn the keyboard down on its face and push the shift lock key out from the back of the keyboard.
  8. Commodore 64 Removing the Shift-Lock Key, Removal of circuit component from shift-lock key (optional): Schritt 8, Bild 1 von 1
    • 8. You can remove the circuit component (gray piece attached to the shift lock key spring) by pulling back slightly on its clip and pulling it apart from the shift lock key button.
    • * Take off the shift key button from the spring by using any Philips screwdriver to pry it off from the spring.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 13-6, Staggers Fall 2014 Mitglied von USF Tampa, Team 13-6, Staggers Fall 2014
USFT-STAGGERS-F14S13G6
4 Mitglieder
15 Anleitungen geschrieben
Ein Kommentar
You should desoder the shift lock wires. Not cut them :(
Darek Greenly - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 2,498
