Zum Hauptinhalt wechseln
Commodore 64 VIC Chip Replacement
Was du brauchst
  1. Commodore 64 VIC Chip Replacement, Removing screws: Schritt 1, Bild 1 von 3 Commodore 64 VIC Chip Replacement, Removing screws: Schritt 1, Bild 2 von 3 Commodore 64 VIC Chip Replacement, Removing screws: Schritt 1, Bild 3 von 3
    • 1. Remove three 6.75mm ph2 screw heads from the casing
  2. Commodore 64 VIC Chip Replacement, Opening: Schritt 2, Bild 1 von 2 Commodore 64 VIC Chip Replacement, Opening: Schritt 2, Bild 2 von 2
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
  3. Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: Schritt 3, Bild 1 von 2 Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: Schritt 3, Bild 2 von 2
    • 1. Detach the multi-colored wire bundles that's connected to the motherboard
  4. Commodore 64 VIC Chip Replacement, Pull up the VIC plate: Schritt 4, Bild 1 von 2 Commodore 64 VIC Chip Replacement, Pull up the VIC plate: Schritt 4, Bild 2 von 2
    • 2. Without using any tools prop up the metal VIC plate with both hands to expose the VIC chip.
  5. Commodore 64 VIC Chip Replacement, Removing the Chip: Schritt 5, Bild 1 von 2 Commodore 64 VIC Chip Replacement, Removing the Chip: Schritt 5, Bild 2 von 2
    • 3. Use a Phillips screwdriver to pry up the VIC chip. Then, use your hands and with small pressure pull it away to remove it from the motherboard.
    • You can insert a new VIC chip by making it clip back in on the board
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 13-6, Staggers Fall 2014 Mitglied von USF Tampa, Team 13-6, Staggers Fall 2014
USFT-STAGGERS-F14S13G6
4 Mitglieder
15 Anleitungen geschrieben
Ein Kommentar
It's awesome to see that people care enough about these machines to make repair guides about them! Great job!
[deleted] - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 24
Insgesamt: 4,815
