Zum Hauptinhalt wechseln
Compact Fluorescent Lightbulb CFL Lightbulb Replacement
  1. Compact Fluorescent Lightbulb CFL Lightbulb Replacement, CFL Lightbulb: Schritt 1, Bild 1 von 2 Compact Fluorescent Lightbulb CFL Lightbulb Replacement, CFL Lightbulb: Schritt 1, Bild 2 von 2
    • Locate the bad bulb and remove it from the socket. This is achieved by grabbing the bulb lightly and rotating counter-clockwise.
    • The bulb may be hot. If so, use gloves, or wait for it to cool.
  2. Compact Fluorescent Lightbulb CFL Lightbulb Replacement: Schritt 2, Bild 1 von 1
    • Procure a new lightbulb, either from a hardware store, or wherever it is you keep new ones.
    • Install the new lightbulb into the socket, this time rotating clockwise.
    • Be sure the power to the socket is turned off before you preform this step. Failure to do so my cause injury.
  3. Compact Fluorescent Lightbulb CFL Lightbulb Replacement: Schritt 3, Bild 1 von 1
    • Turn the power on to the light socket by means of a switch or knob.
    • Congratulations! You have successfully changed a lightbulb! Reward your efforts by getting a cold beverage of your choice.
Ziellinie
12 weitere Nutzer:innen haben diese Anleitung absolviert.
WiseGeek
1.364 Reputation
2 Anleitungen geschrieben
Ein Kommentar
You shouldn't unscrew/screw CFL Bulb from its tube because there is a very small risk that it will break (Especially if it has the tubular shape (2U, 3U and 4U)). Try to unscrew/screwing it from its plastic base.
Jokid - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 7,893
