Einleitung
You will need to assemble the proper tools shown in the first step of this guide before you continue forward.
This guide is meant to assist the reader with the proper steps to remove and replace the keyboard of the Compaq Evo N1000v device.
Ersatzteile
Kein Ersatzteil erforderlich.
Carefully remove the screws located inside the red circles.
  • Carefully remove the screws located inside the red circles.
Kommentar hinzufügen
Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel. Push down on the spudger to lift the LED display panel upward.
  • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
  • Push down on the spudger to lift the LED display panel upward.
  • Do this on both the left and right sides of the device as shown in the images.
Completely remove the LED display panel from the device.
  • Completely remove the LED display panel from the device.
Left the keyboard up from the back end as shown in the image.
  • Left the keyboard up from the back end as shown in the image.
Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
  • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
  • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
  • Repeat this action on the right side of the lock.
Pull the keyboard upward to remove it from the device.
  • Pull the keyboard upward to remove it from the device.
  • Repeat these steps in reverse order to install the new keyboard.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
ryan
Mitglied seit 12.03.2014
470 Reputation
4 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 184
