Einleitung
You will need to assemble the proper tools shown in the first step of this guide before you continue forward.
This guide is meant to assist the reader with the proper steps to remove and replace the rear fan of the Compaq Evo N1000v device.
Was du brauchst
Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
Push down on the spudger to lift the LED display upward.
Do this on both the left and right sides of the device as shown in the images.
Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
Repeat this action on the right side of the lock.
Remove the rear fan.
Repeat these steps in reverse order to install the new rear fan.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
My Big Thanks! I cleaned the radiator, cooler greased and replaced the thermal grease from the CPU and GPU.
