Zum Hauptinhalt wechseln
Compaq Evo N1000v Rear Fan Replacement
Was du brauchst
  1. Compaq Evo N1000v Rear Fan Replacement, Rear Fan: Schritt 1, Bild 1 von 1
    • Carefully remove the screws located inside the red circles.
  2. Compaq Evo N1000v Rear Fan Replacement: Schritt 2, Bild 1 von 2 Compaq Evo N1000v Rear Fan Replacement: Schritt 2, Bild 2 von 2
    • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
    • Push down on the spudger to lift the LED display upward.
    • Do this on both the left and right sides of the device as shown in the images.
  3. Compaq Evo N1000v Rear Fan Replacement: Schritt 3, Bild 1 von 1
    • Completely remove the LED display panel from the device.
  4. Compaq Evo N1000v Rear Fan Replacement: Schritt 4, Bild 1 von 1
    • Lift the keyboard up from the back end as shown in the image.
  5. Compaq Evo N1000v Rear Fan Replacement: Schritt 5, Bild 1 von 1
    • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
  6. Compaq Evo N1000v Rear Fan Replacement: Schritt 6, Bild 1 von 1
    • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
    • Repeat this action on the right side of the lock.
  7. Compaq Evo N1000v Rear Fan Replacement: Schritt 7, Bild 1 von 1
    • Pull the keyboard upward to remove it from the device.
  8. Compaq Evo N1000v Rear Fan Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the 3 screws as shown in the photo.
  9. Compaq Evo N1000v Rear Fan Replacement: Schritt 9, Bild 1 von 1
    • Remove the cable with the grip tweezers as shown in the photo.
  10. Compaq Evo N1000v Rear Fan Replacement: Schritt 10, Bild 1 von 1
    • Remove the rear fan.
    • Repeat these steps in reverse order to install the new rear fan.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
ryan
470 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 2-1, Vijaybhaskar Spring 2014 Mitglied von UMass Dartmouth, Team 2-1, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S2G1
3 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
My Big Thanks! I cleaned the radiator, cooler greased and replaced the thermal grease from the CPU and GPU.
DeK-Test New - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 378
