Zum Hauptinhalt wechseln
Compaq Presario CQ60 Keyboard Bezel Replacement
Was du brauchst
  1. Compaq Presario CQ60 Keyboard Bezel Replacement, Slide battery latch: Schritt 1, Bild 1 von 2 Compaq Presario CQ60 Keyboard Bezel Replacement, Slide battery latch: Schritt 1, Bild 2 von 2
    • Slide battery latch to left
    • Simultaneously lift battery
  2. Compaq Presario CQ60 Keyboard Bezel Replacement: Schritt 2, Bild 1 von 3 Compaq Presario CQ60 Keyboard Bezel Replacement: Schritt 2, Bild 2 von 3 Compaq Presario CQ60 Keyboard Bezel Replacement: Schritt 2, Bild 3 von 3
    • Lift and remove battery
  3. Compaq Presario CQ60 Keyboard Bezel Replacement, Unscrew keyboard: Schritt 3, Bild 1 von 2 Compaq Presario CQ60 Keyboard Bezel Replacement, Unscrew keyboard: Schritt 3, Bild 2 von 2
    • Remove 3x M2.5x4mm
  4. Compaq Presario CQ60 Keyboard Bezel Replacement, Lift keyboard: Schritt 4, Bild 1 von 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Lift keyboard: Schritt 4, Bild 2 von 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Lift keyboard: Schritt 4, Bild 3 von 3
    • Lift the keyboard in the middle with a spudger
    • Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
    • Do not remove the keyboard fully, it is attached via a ribbon cable
  5. Compaq Presario CQ60 Keyboard Bezel Replacement, Detach ribbon cable: Schritt 5, Bild 1 von 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Detach ribbon cable: Schritt 5, Bild 2 von 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Detach ribbon cable: Schritt 5, Bild 3 von 3
    • Lift keyboard slightly
    • Push each side of ribbon cable connector
    • Fully remove keyboard
  6. Compaq Presario CQ60 Keyboard Bezel Replacement, Remove screws: Schritt 6, Bild 1 von 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Remove screws: Schritt 6, Bild 2 von 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Remove screws: Schritt 6, Bild 3 von 3
    • Remove 2x Phillips M2.5x8mm screws from under the display
    • Remove 4x Phillips M2x2.8mm screws from the battery compartment
  7. Compaq Presario CQ60 Keyboard Bezel Replacement, Disconnect ribbon cable: Schritt 7, Bild 1 von 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Disconnect ribbon cable: Schritt 7, Bild 2 von 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Disconnect ribbon cable: Schritt 7, Bild 3 von 3
    • Turn over the laptop
    • Use a spudger to lift the ribbon cable hinged clip
    • Pull the ribbon cable out of the connector
  8. Compaq Presario CQ60 Keyboard Bezel Replacement: Schritt 8, Bild 1 von 2 Compaq Presario CQ60 Keyboard Bezel Replacement: Schritt 8, Bild 2 von 2
    • Lifting the bezel by the screen
    • Slide the bezel back towards the screen to release it from the clips
  9. Compaq Presario CQ60 Keyboard Bezel Replacement, Remove bezel: Schritt 9, Bild 1 von 1
    • Fully remove bezel
Abschluss
Mike B
1.045 Reputation
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 290
