Was du brauchst
Remove 3 M2.5x4mm screws
Slide caddy forwards
Lift tab to remove caddy
Lift the keyboard in the middle with a spudger
Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
Do not remove the keyboard fully, it is attached via a ribbon cable
Lift keyboard slightly
Push each side of ribbon cable connector
Fully remove keyboard
Remove 2x Phillips M2.5x8mm screws from under the display
Remove 4x Phillips M2x2.8mm screws from the battery compartment
Turn over the laptop
Use a spudger to lift the ribbon cable hinged clip
Pull the ribbon cable out of the connector
Lifting the bezel by the screen
Slide the bezel back towards the screen to release it from the clips
Remove 4x #1 Phillips M2.5x8mm screws from the bottom case
Remove 2x #0 Phillips M2x4mm screws from hard drive bay
Using a spudger lift the mouse ribbon cabe latch
Do not remove yet
Starting at the edge by the screen, use a spudger to unclip the top case
Work around both sides and finish with the touchpad
Lift top base off of laptop, being careful to disconnect the touchpad ribbon cable
Disconnect speaker connector. This connector is easy to break, there are 2 tabs on the bottom that need to be lifted slightly to remove. Use a spudger carefully under the connector to lift slightly and pull gently on the wires all together to remove.
Disconnect the USB connector
Remove 2x #1 Phillips M2.5x4.5mm screws holding the optical drive connector
Remove the modem port connector
Remove 1x #0 Phillips M2x2.8mm screw from left speaker
Lift speaker out and place out of the way of the motherboard
Lift motherboard from right hand side and slide towards right
Be careful of power connector releasing from case
Eine weitere Person hat diese Anleitung absolviert.
