Zum Hauptinhalt wechseln
Compaq Presario CQ60-211DX Display Assembly Replacement
Was du brauchst
  1. Compaq Presario CQ60-211DX Display Assembly Replacement, Display Assembly: Schritt 1, Bild 1 von 1
    • Start by making sure the CQ60 is powered down and that the disk drive is empty.
    • Flip the device over and remove the battery.
  2. Compaq Presario CQ60-211DX Display Assembly Replacement: Schritt 2, Bild 1 von 2 Compaq Presario CQ60-211DX Display Assembly Replacement: Schritt 2, Bild 2 von 2
    • Remove the rubber screw covers next to each of the two screen hinges using a metal spudger.
    • Unscrew the screws underneath the rubber cover using the blank Phillips-head screwdriver.
  3. Compaq Presario CQ60-211DX Display Assembly Replacement: Schritt 3, Bild 1 von 2 Compaq Presario CQ60-211DX Display Assembly Replacement: Schritt 3, Bild 2 von 2
    • Use the metal spudger to gently pry the plastic faceplate off the rest of the display.
  4. Compaq Presario CQ60-211DX Display Assembly Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the two screws in the top corners to separate the frame holding the assembly from the plastic of the lid.
  5. Compaq Presario CQ60-211DX Display Assembly Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the assembly from the chip located between the hinges by pulling the wires to the right.
  6. Compaq Presario CQ60-211DX Display Assembly Replacement: Schritt 6, Bild 1 von 1
    • Pull the frame forward, and then unscrew the three screws on each side.
  7. Compaq Presario CQ60-211DX Display Assembly Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the ribbon cable on the back of the display by peeling back the tape and then pulling down on the cable.
Abschluss
Garrett Carter
471 Reputation
4 Anleitungen geschrieben
2 Kommentare
My laptop model Compaq predario cq61 h
Rashid 007 - Antwort
Computer on but display light of computer is running
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 27
Insgesamt: 1,109
