Einleitung
This guide will show how to remove and replace the display assembly on a Compaq Presario CQ60-211DX laptop.
Was du brauchst
Start by making sure the CQ60 is powered down and that the disk drive is empty.
Flip the device over and remove the battery.
Remove the rubber screw covers next to each of the two screen hinges using a metal spudger.
Unscrew the screws underneath the rubber cover using the blank Phillips-head screwdriver.
Use the metal spudger to gently pry the plastic faceplate off the rest of the display.
Unscrew the two screws in the top corners to separate the frame holding the assembly from the plastic of the lid.
Disconnect the assembly from the chip located between the hinges by pulling the wires to the right.
Disconnect the ribbon cable on the back of the display by peeling back the tape and then pulling down on the cable.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
My laptop model Compaq predario cq61 h
Computer on but display light of computer is running
