Zum Hauptinhalt wechseln
Compaq Presario CQ62-215dx CPU Replacement
Was du brauchst
  1. Compaq Presario CQ62-215dx CPU Replacement, CPU: Schritt 1, Bild 1 von 1
    • Turn the laptop upside down.
    • Remove all the 3.0mm Phillips #00 screws from the back cover.
  2. Compaq Presario CQ62-215dx CPU Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery, RAM, and hard drive.
  3. Compaq Presario CQ62-215dx CPU Replacement: Schritt 3, Bild 1 von 1
    • Remove four 1.2mm Phillips #00 screws under the battery.
  4. Compaq Presario CQ62-215dx CPU Replacement: Schritt 4, Bild 1 von 1
    • Turn the laptop over, and open the laptop cover.
    • Use a spudger or your hand to carefully remove the keyboard.
  5. Compaq Presario CQ62-215dx CPU Replacement: Schritt 5, Bild 1 von 1
    • Use a spudger or your hand to lift the outside frame from the corner of the laptop.
  6. Compaq Presario CQ62-215dx CPU Replacement: Schritt 6, Bild 1 von 1
    • Remove all the 1.2mm Phillips #00 screws from the motherboard and in the top corner that secures the fan.
  7. Compaq Presario CQ62-215dx CPU Replacement: Schritt 7, Bild 1 von 1
    • Unplug the wires connected to the motherboard with a spudger.
  8. Compaq Presario CQ62-215dx CPU Replacement: Schritt 8, Bild 1 von 1
    • Remove the two 3mm Phillips #00 screws beside the fan.
  9. Compaq Presario CQ62-215dx CPU Replacement: Schritt 9, Bild 1 von 1
    • Lift the motherboard out carefully.
  10. Compaq Presario CQ62-215dx CPU Replacement: Schritt 10, Bild 1 von 1
    • When the motherboard is removed, flip it over, and you will have a view just like in the picture.
  11. Compaq Presario CQ62-215dx CPU Replacement: Schritt 11, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the three 2mm screws that connect the fan to the CPU.
  12. Compaq Presario CQ62-215dx CPU Replacement: Schritt 12, Bild 1 von 1
    • Remove the fan from the motherboard.
    • When reassembling, you will need to solder the fan back on to the CPU.
  13. Compaq Presario CQ62-215dx CPU Replacement: Schritt 13, Bild 1 von 1
    • Use the metal spudger to twist the lock tab on the component.
  14. Compaq Presario CQ62-215dx CPU Replacement: Schritt 14, Bild 1 von 1
    • Remove current CPU and replace with new component.
Abschluss
UMass Dartmouth, Team S4-G1, Valliere Spring 2019 Mitglied von UMass Dartmouth, Team S4-G1, Valliere Spring 2019
UMASSD-VALLIERE-S19S4G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 1,244
