Einleitung
Poor ventilation can cause heat to build up very quickly in your laptop. When the temperatures inside the case rise to excessive amounts due to a faulty fan, the risk of damaging important internal components increases and your laptop could shut down.
Was du brauchst
Turn the laptop upside down, and unscrew all the 3.0mm screws on the back cover with a Phillips screwdriver.
There are four 1.2mm screws under the battery that are needed to be removed with a Phillips screwdriver.
Turn the laptop back, and open the laptop cover. Use a spudger or your hand to carefully remove the keyboard.
Once the keyboard is out, use the Metal Spudger or your hand in the corner of the laptop to lift the outside frame.
Unscrew all the 1.2mm screws on the motherboard and in the top corner that secures the fan with a Phillips screwdriver.
If all the screws have been removed, you should be able to lift the motherboard out carefully.
When the motherboard is removed, flip it over, and you will have a view just like in the picture.
Use the Phillips screwdriver to unscrew the three 2mm screws that connect the fan to the CPU.
