Zum Hauptinhalt wechseln
Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement
Was du brauchst
  1. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • First you will need to turn the laptop upside down.
  2. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by pushing the switch to the left and removing the battery from its slot.
  3. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the three 3mm screws on the compartment underneath the battery.
  4. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 3mm screws on the lowest compartment.
  5. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: Schritt 5, Bild 1 von 1
    • Use a Metal Spudger remove the panel. Underneath is where the hard drive is connected .
  6. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: Schritt 6, Bild 1 von 1
    • This is where you detach your old hard drive and replace with the new component.
Abschluss
UMass Dartmouth, Team S4-G1, Valliere Spring 2019 Mitglied von UMass Dartmouth, Team S4-G1, Valliere Spring 2019
UMASSD-VALLIERE-S19S4G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 348
