Zum Hauptinhalt wechseln
Compaq Presario V2414NR Optical Drive Replacement
Was du brauchst
  1. Compaq Presario V2414NR Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR Optical Drive Replacement: Schritt 2, Bild 1 von 2 Compaq Presario V2414NR Optical Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR Optical Drive Replacement, Optical Drive: Schritt 3, Bild 1 von 2 Compaq Presario V2414NR Optical Drive Replacement, Optical Drive: Schritt 3, Bild 2 von 2
    • On the optical drive there is small pin hole. Insert a paperclip or similarly sized object in the hole.
    • The Drive will pop a short way out of the computer.
  4. Compaq Presario V2414NR Optical Drive Replacement: Schritt 4, Bild 1 von 3 Compaq Presario V2414NR Optical Drive Replacement: Schritt 4, Bild 2 von 3 Compaq Presario V2414NR Optical Drive Replacement: Schritt 4, Bild 3 von 3
    • Remove the 7mm Phillips #1 screw that secures the optical drive to the computer.
    • Grip the sides of the Optical Drive and slide it out until it is completely removed from the computer.
    • When reassembling, slide the optical drive straight in until it clicks.
Abschluss
Rylie Schmidt
765 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 2-1, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G1
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 245
