Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the battery before starting
    • Remove the battery before starting
  2. Loosen the two screw for the hard drive cover The screws will stay attached the the cover
    • Loosen the two screw for the hard drive cover
    • The screws will stay attached the the cover
    • Lift the cover from the left side and remove
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Lift the black pull tab on the hard drive Lift the drive straight up out of the laptop
    • Lift the black pull tab on the hard drive
    • Lift the drive straight up out of the laptop
  5. Remove the four screws on the sides of the drive (two on each side) Remove the hard drive from the caddy
    • Remove the four screws on the sides of the drive (two on each side)
    • Remove the hard drive from the caddy
  6. Pull the IDE connecter straight off the drive
    • Pull the IDE connecter straight off the drive
    • Be sure to pull the connecter off straight so as not to bend the hard drive IDE pins
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Andrew
1.164 Reputation
5 Anleitungen geschrieben
Perfect instructions....easy directions even for a computer dunce like me...
John Platania - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 7
Letzte 7 Tage: 23
Letzte 30 Tage: 62
Insgesamt: 6,893
