Zum Hauptinhalt wechseln
Compaq Presario v2000 RAM Replacement
Was du brauchst
  1. Compaq Presario v2000 RAM Replacement, Removing the RAM cover: Schritt 1, Bild 1 von 2 Compaq Presario v2000 RAM Replacement, Removing the RAM cover: Schritt 1, Bild 2 von 2
    • Loosen the 2 Phillips screws with RAM icons above them. Don’t worry if the screws won’t come out, as they’re attached to the door.
    • Lift the RAM door up and away.
  2. Compaq Presario v2000 RAM Replacement, Removing the existing RAM: Schritt 2, Bild 1 von 3 Compaq Presario v2000 RAM Replacement, Removing the existing RAM: Schritt 2, Bild 2 von 3 Compaq Presario v2000 RAM Replacement, Removing the existing RAM: Schritt 2, Bild 3 von 3
    • There are two metal clips holding both RAM modules in place.
    • To unclip them, push them both outwards from the RAM stick with your fingers until it pops out and sticks up at an angle.
    • Pull the stick of RAM out.
    • Repeat the last 3 steps for the bottom RAM stick.
  3. Compaq Presario v2000 RAM Replacement, Installing the new RAM: Schritt 3, Bild 1 von 2 Compaq Presario v2000 RAM Replacement, Installing the new RAM: Schritt 3, Bild 2 von 2
    • Start at the bottom slot. Insert the new RAM at the same angle the previous RAM popped out at.
    • Push the RAM in until a click is heard.
    • Repeat the last 2 steps for the top slot.
  4. Compaq Presario v2000 RAM Replacement, Reinstalling the RAM cover: Schritt 4, Bild 1 von 1
    • Repeat the first part of this guide to reinstall the RAM door.
Abschluss
If you encounter problems after installing new RAM, redo this guide, or follow a RAM troubleshooting guide.
Viscous
381 Reputation
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 20
Insgesamt: 313
