Zum Hauptinhalt wechseln
Computer King Muffin Kinder 7 Logic Board Replacement
Was du brauchst
  1. Computer King Muffin Kinder 7 Logic Board Replacement, Logic Board: Schritt 1, Bild 1 von 2 Computer King Muffin Kinder 7 Logic Board Replacement, Logic Board: Schritt 1, Bild 2 von 2
    • Use the plastic opening tool help push out the microSD card from the microSD slot.
  2. Computer King Muffin Kinder 7 Logic Board Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to unclip the plastic front from the plastic back. Use the MicroSD slot to initially start the unclipping.
  3. Computer King Muffin Kinder 7 Logic Board Replacement: Schritt 3, Bild 1 von 2 Computer King Muffin Kinder 7 Logic Board Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the nine 3.0 mm Phillips #00 screws.
  4. Computer King Muffin Kinder 7 Logic Board Replacement: Schritt 4, Bild 1 von 1
    • The battery is glued onto the black plastic. Use the plastic opening tool to pry the battery from the black plastic
  5. Computer King Muffin Kinder 7 Logic Board Replacement: Schritt 5, Bild 1 von 3 Computer King Muffin Kinder 7 Logic Board Replacement: Schritt 5, Bild 2 von 3 Computer King Muffin Kinder 7 Logic Board Replacement: Schritt 5, Bild 3 von 3
    • Unsolder the 11 red, back, and grey wires connected to the logic board.
    • Tips on how to solder can be found here.
  6. Computer King Muffin Kinder 7 Logic Board Replacement: Schritt 6, Bild 1 von 3 Computer King Muffin Kinder 7 Logic Board Replacement: Schritt 6, Bild 2 von 3 Computer King Muffin Kinder 7 Logic Board Replacement: Schritt 6, Bild 3 von 3
    • Use the flat end of the spudger to lift the black panels covering the three ribbon cables connected to the logic board.
  7. Computer King Muffin Kinder 7 Logic Board Replacement: Schritt 7, Bild 1 von 1
    • Pull the three ribbon cables out so that they are no longer connected to the logic board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Katherine
439 Reputation
3 Anleitungen geschrieben
UWT Liner: Group 2 Mitglied von UWT Liner: Group 2
Community
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 233
