Zum Hauptinhalt wechseln
Computer King Muffin Kinder 7 Screen Replacement
Was du brauchst
  1. Computer King Muffin Kinder 7 Screen Replacement, Screen: Schritt 1, Bild 1 von 2 Computer King Muffin Kinder 7 Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • Use the plastic opening tool help push out the microSD card from the microSD slot.
  2. Computer King Muffin Kinder 7 Screen Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to unclip the plastic front from the plastic back. Use the MicroSD slot to initially start the unclipping.
  3. Computer King Muffin Kinder 7 Screen Replacement: Schritt 3, Bild 1 von 2 Computer King Muffin Kinder 7 Screen Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the nine 3.0 mm Phillips #00 screws.
  4. Computer King Muffin Kinder 7 Screen Replacement: Schritt 4, Bild 1 von 1
    • The battery is glued onto the black plastic. Use the plastic opening tool to pry the battery from the black plastic
  5. Computer King Muffin Kinder 7 Screen Replacement: Schritt 5, Bild 1 von 2 Computer King Muffin Kinder 7 Screen Replacement: Schritt 5, Bild 2 von 2
    • There will be a black strip connected to the screen.
    • Use the pointy end of the spudger to unstick the black strip that is glued onto the screen.
  6. Computer King Muffin Kinder 7 Screen Replacement: Schritt 6, Bild 1 von 3 Computer King Muffin Kinder 7 Screen Replacement: Schritt 6, Bild 2 von 3 Computer King Muffin Kinder 7 Screen Replacement: Schritt 6, Bild 3 von 3
    • You will need to remove 2 ribbon cables, one that is connected to the touch screen (by the battery) and one that is connected to the yellow plastic (by the speaker).
    • Use the flat end of the spudger to lift the black panel covering the ribbon cables.
  7. Computer King Muffin Kinder 7 Screen Replacement: Schritt 7, Bild 1 von 1
    • Pull the two ribbon cables out so that they are no longer connected to the logic board.
  8. Computer King Muffin Kinder 7 Screen Replacement: Schritt 8, Bild 1 von 1
    • Lift up the logic board and black plastic so that they are no longer covering the screen
    • Lift out the screen.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Katherine
439 Reputation
3 Anleitungen geschrieben
UWT Liner: Group 2 Mitglied von UWT Liner: Group 2
Community
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 537
